2003 Polaris 330 Magnum electrical problem, I think??
I am having a problem with this machine that is driving me nuts. It starts, but has not power when I squirt the gas. Thought it might be the carb, took that off, cleaned and rebuilt it. Decided it might be the timing, connected the timing light to check that and the timing light is intermittent at idle and no light when bringing the rpm's up. Thinking it is an electrical issue, any advice where I should start?
This 5 buck manual can save you from hair pulling and frustration.Has good electrical resistance and trouble shooting checks on the stator,pick up coil,ign coil and wiring diagram.2003 Polaris Magnum 330 Service Manual PDF Download Plus it wouldn't surprise me that the problem could be ecm related as it controls so many things.It's addressed in the manual also. Item#27.
Don't want to say ecm but they did have their share of problems. Go through the ignition checks first such as pulling the black wire from the cdi to eliminate the ignition switch and left control switch. That's the first check on the trouble shooting guide.Then follow the guide on down. Also resistance checks on the pick up coil and stator. If these check out,I'd be leaning toward an ecm module,but make sure as it's a high dollar item.
dennisaccord
8
04-24-2017 08:13 AM
MikeyBoyesq
04-14-2017 09:35 AM
Polarisman1123
04-08-2017 06:13 PM
jrsavoie
11
04-06-2017 03:31 PM
