Dang limp mode won't reset
Old 09-17-2017, 12:16 AM
J s Wild's Avatar
Default Dang limp mode won't reset
New to the quad gig here, seen a lotta good info, I need to re ask a question that I've seen a few threads on. Have an 05 arctic cat 650 v2 4x4, can't get limp to reset. Have done all the recommendations, every reset video and forum I can find. Limp mode won't reset. Changed belt, flipped switch, jumped plugs, yadda yadda. Will not reset. Is there a way to bypass the switch? It would be a normally open switch right? Can I not just jump it, or slap a relay in there to get by, or is there a deeper problem that I haven't heard about?
Old 09-17-2017, 10:06 AM
Zrock's Avatar
Depends why limp mode was activated. Their may be a bigger issue causing it to come back as soon as you fire machine. Mine limp mode went away on its own as soon as the issue was fixed..
Old 09-17-2017, 11:18 AM
J s Wild's Avatar
Such as? I can't seem to find anything that goes into more detail on what could set it off.
Where's the best place to find repairs book?
Every time I try, all I get is hits on 04,06 models. I'd feel better if I had an actual book instead of a PDF.
Old 09-17-2017, 11:24 AM
Zrock's Avatar
Just take the pdf to your local printer may be cheaper than buying a service manual from the dealer.. I just usually print off the pages I need at the time
Old 09-17-2017, 01:09 PM
J s Wild's Avatar
Good idea. Do you know of other problems that could trip that switch? I plan opening up the cover again to see if tripped, kinda odd with a brand new belt, but I gotta start somewhere.
Old 09-17-2017, 09:22 PM
Zrock's Avatar
