1999 Polaris Xplorer 400- 3wd....
Old 05-05-2018, 09:04 PM
PolarisXP's Avatar
Today i spent several hours getting main bearings replaced and crank installed. Everything is ready for the halves to go together! On one
of the YouTube vids i found, the guy placed an o ring between the crank and bearing instead of bearing and collar. Parts diagram has o ring between bearing and collar, which makes sense. Just verifying.
  #282
Old 05-20-2018, 04:17 PM
PolarisXP's Avatar
Got halves together, right cover on, and after I install the crank nut the stator, flywheel, and recoil are going on. Then I am done! Oh yeah, and the jug and head are already done.
  #283
Old 05-29-2018, 08:46 PM
PolarisXP's Avatar
Completely done with rebuild! Finally. Sounds good, not much different than before but wayyy more compression. Replaced u joints on prop shaft so we are good to go. Still getting over the fact that OPT will not be commenting anymore...
  #284
Old 05-29-2018, 11:00 PM
user493's Avatar
Moto Psycho
"Still getting over the fact that OPT will not be commenting anymore..." Yeah, I miss him. It's good to hear you got it up and running again. I didn't know how that weld was going to turn out but it works, so it must have been good.
  #285
Old 05-30-2018, 07:06 AM
PolarisXP's Avatar
Yep, he definitely left a large set of shoes to be filled. I hope it holds, I guess it is basically a large clump of aluminum so i think it will be alright.
  #286
Old 06-12-2018, 09:57 PM
PolarisXP's Avatar
Does anyone have a recommendation for the lower steering post bushing? I have heard anything is better than stock. Already tried Rick, doesn't make the brass version anymore.
  #287
Old 06-18-2018, 10:14 PM
PolarisXP's Avatar
Replaced both steering post bushings the other day. Now I can feel a hint of a left outer tie rod end, but it isn't bad enough to qualify for replacement,. Getting ready to hit the dunes!
  #288
Old 06-18-2018, 10:40 PM
user493's Avatar
Moto Psycho
Did you end up using stock bushings? They're not something I would think there's a big aftermarket demand for.
  #289
Old 06-19-2018, 07:50 AM
PolarisXP's Avatar
Yes. Actually it was a Caltric. I got an armature plate, brake pads, and now these bushings. Seem to be good quality
  #290
Old 06-23-2018, 12:52 PM
PolarisXP's Avatar
I have had a little trouble with the bike slipping out of high gear. Mostly when you shift from low to high and the initial acceleration is when it happens. Once it is in there is not a problem. Could it be the linkage adjustment?
Quick Reply: 1999 Polaris Xplorer 400- 3wd....
