bleeding brake
Make sure it's full of fluid. Squeeze the handle 3 or 4 times and hold in in on the last squeeze. Open the bleeder and the handle should go all the way to the grip. Keep holding it in until the bleeder is closed. repeat until the is no more air in the system.
Do both sides and start with the left one then the right one.
If you have no resistance in the handle at all you can open the bleeder and slowly pull the handle in and hold it until the bleeder is closed.
I you get no fluid squirting out of the bleeder the you may need a new or rebuilt master Cylinder.
