Sport Quads Discussions on sport quads.
Best Z400 setup
Old Feb 5, 2004 | 12:43 AM
juldan's Avatar
Default Best Z400 setup
What the best setuo for the Z400. what pipes jetiing etc. Are slip-ons worth the bucks
Old Feb 5, 2004 | 04:40 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
K&N with Outerwears, FMF PowerBomb Header and Ti-4 Muffler. Really woke the engine up, particularly on the low end.
Old Feb 5, 2004 | 04:12 PM
Corpsie's Avatar
Take off the snorkel noise baffle, also the airbox lid if you're daring, and rejet (to a 140 or 145). ~$7 later you'll have way more** low and mid rpm torque.
If you feel the need to get a new filter, screw K&N's, they're way overpriced and let in dirt like you wouldn't believe. I've heard they're worse for letting sand in than foam filters, but that's just what I "heard". I've actually seen K&N's let dirt by.
K&N + adaptor is around $90
Aftermarket Foam filter is $20
Are slip ons worth it? not really.
Are full systems worth it? not really.
Are either of those more worth it if you get a stroker kit and/or cams? could be.
Pipes don't affect 4 strokes as much as they do with 2 strokes.
If you want best the setup for every dollar spent, check out my site http://atv.corpsie.com
If you want the absolute best set up regardless of money, then just go all out get a stroker kit, high compression piston, ignition system, full exhaust, aluminum radiator, edelbrock carburetor, cams, etc...
** keep in mind that I did this mod BEFORE altering my exhaust pipe, so I know what the effect is. Some people do all these mods at once and can't really target what mod had what effect.
Old Mar 28, 2004 | 11:00 PM
OnlyTheBest's Avatar
How do you get the baffle out of the z400 stock pipe it is welded onto the pipe end?
Old Mar 29, 2004 | 11:11 AM
Corpsie's Avatar
It's not welded, it's just plastic snapped together.
http://atv.corpsie.com/index.html?mod=005
Old Apr 1, 2004 | 05:16 AM
JRA's Avatar
JRA
Are you talking about the peashooter in the pipe end?
If so, you just need a 1 1/4" hole saw and cut it out. Your spark arrester will stay intact.
Doubt there is any power gain, but it sounds more throaty expecially at idle.
Old Apr 1, 2004 | 01:57 PM
KFXCarnage's Avatar
Yea I don't think its plastic from what I remember its 3 tac welds.I will know for sure when I get home and look again.
Yea you can just hack it off.Doesn't hurt a thing but is way louder.Noticable punch I thought when I did mine.I just took the guts out and left them out..
NewGuy2481
Oct 6, 2015 05:54 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
jbrewster94
Sep 23, 2015 04:16 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
