400ex vs z400 vs warrior
[i]Originally posted by: DVX32[/i
There is no way stock gearing would go 68...i dont care how many mods you got without changing the gearing you would only gain about 2-3mph...yell at me if i'm wrong but thats as far as i understand...otherwise the engine wouldnt rev high enough
going on night time, approximately 2.5km run, hard packed dirt road, around 8°C and a very slight down grade. So slight that if you were stopped and pulled in your clutch, you'd have to push with your feet to get it rolling. The bike setup was the same as you see in my sig, only with the stock gearing at 13/40. 13/40 and 22" tires in 6th gear on a Warrior is probably good for just over 70mph, but the bike just doesn't have the power to pull that speed.
Anyhoo, like I said, you can believe it or not, it's up to you. I was there .. were you?
