Sport Quads Discussions on sport quads.
chain lube
Old May 24, 2004 | 01:22 PM
Karnage's Avatar
Default chain lube
whats the best kind of chain lube or does it even matter really?
Old May 24, 2004 | 07:42 PM
speeeedy's Avatar
Default chain lube
amsoil hd imho
Old May 24, 2004 | 08:05 PM
modquad's Avatar
Default chain lube
Tri-flow. It's teflon is also great for any and all steering pivots also.
Old May 24, 2004 | 09:26 PM
Trasher's Avatar
Default chain lube
trails or sand?
Old May 24, 2004 | 10:04 PM
Karnage's Avatar
Default chain lube
trails... i wont ride sand for a good while yet.. id love to tho but oh well
Old May 25, 2004 | 05:00 AM
BigBadScrambler's Avatar
Default chain lube
Ditto
Old May 25, 2004 | 09:19 PM
SpeedDemon13's Avatar
Default chain lube
ya i like tri-flow
Old May 25, 2004 | 09:30 PM
Karnage's Avatar
Default chain lube
where can i get this tri-flow stuff in canada?
Old May 25, 2004 | 09:34 PM
clover's Avatar
Default chain lube
hey whats the best chain lube that don't sling stuff that bad,but keeps the chain wet and sticky,i've tried bel-ray superclean its good for not slinging stuff,but it wheres off in like a day.
Old May 26, 2004 | 12:47 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default chain lube
An O-ring chain is permenantly lubed internally at the factory with grease. The rings are there to hold the grease in place. All you need, is something that will keep the rings supple, and provide some lubrication externally between the chain and the sprockets.
So, NEVER NEVER USE ANY LUBE THAT IS WET! Think about it. That wet lube is going to attract dirt, then form GRINDING PASTE and tear your O-rings to shreds! Then that internal grease is lost, and you are going to need a new chain! And, penetrating lubes will slip past the O-rings and get inside and ruin the grease, so avoid those also.
I use Maxima CHAIN WAX, and nothing else! These are dirt bikes, not street bikes.
