hp of my raptor 350
hp of my raptor 350
If you buy an exhaust, filter or jet kit, the hp numbers the box says you will gain are almost always bull sh*t! The guy that said you only have about 24hp max is prolly exactly right. And if you are getting 24hp at the crank your prolly getting 16-17 at the wheels. Run it on a dyno and i bet these numbers will be pretty accurate. IMO
hp of my raptor 350
Stock raptor 350 is 22, hmf says 21, they only gain about 1 peak HP with the sport series pipe, check the site for the dyno runs, but you gain alot more in the midrange, its probably like a 3-4 hp gain through the fat part of the powerband. Opened up and jetted properly i would say your maybe at 25 hp at the most. The headpipe you have did ABSOLUTELY nothing for you expect look pretty, so don't expect much more from your pipe then the HMF. Without tearing into the motor, cam, piston, etc. your not going to break 25.
#15
hp of my raptor 350
Originally posted by: Trevor
How much hp would a 2002 300ex with a full dg exhaust,jetted,k&n filter with 20" rear tires 13/36 gearing?
The best deal for a 300ex is the FMF Megamax, full system is only around 250 and it gives descent gains and a good sound when you pull the core out.
#16
#17
hp of my raptor 350
Oh I didn't see you already have a DG[img]i/expressions/face-icon-small-blush.gif[/img] Well Im not sure what yours is I do see it has a end cap at least. The system DG sold a buddy of mine is junk, it doesn't even have a end cap adn you can see the inside welds[img]i/expressions/face-icon-small-shocked.gif[/img] How does yours sound?
#19
#20
hp of my raptor 350
I find it too loud I would like a deeper tone to it. The end cap with the plates in it is actualy a supertrap end piece.
