z400 tire pressure
I always replace my stock tires first thing, so I haven't ever run them, but the plaque on the fender says 4.4 front and 4.0 rear, so that's where I would start...........
It depends.......
But I generally run them between 5-9psi. I run them a little harder because I'm heavier than the standard z400 rider and 4.4psi is only for the standard weight....... I believe the bead weight on those Dunlops is around 36psi, in general you can run up to 25% of the total psi without any problems.........
oliveiracarlos
Sep 7, 2015 03:39 AM
