Sport Quads Discussions on sport quads.
Z400 chain breaks?
Old Jan 19, 2014 | 06:05 PM
JakeRokjer's Avatar
I think ill buy a good o ring chain. My swing arm bearings are good i think. My chain had the perfect amount of play
Old May 3, 2014 | 07:44 AM
95wolv's Avatar
Make sure the chain tension adjustment is equal, the Suzuki set up is a bit hard to get even, and if it is crooked even a little, it will fling chains and cause problems. you have to get both side exactly the same or the sprocket will be at a slight angle to the chain, which will cause excessive wear and make it easier for the chain to roll off the sprocket.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
merryman
Sep 19, 2015 03:15 AM
nastyblaster100
Sep 13, 2015 01:19 PM
