07 Suzuki raptor
So you push the start button and you can hear the starting motor cranking over but it's not turning the engine. The quad will run if bump started.
I'm not sure any more on the mechanisim on that quad but I believe there is a kind of plunger action so that when the start motor spins it engages with the flywheel, but when it's not spinning, the two are not in contact. Seems to me that plunger action isn't happening.
Try posting in the yamaha section as this is the same quad as the Warrior. People may be thrown off by your title as the quad is not a Suzuki.
Good luck.
Good luck.
Alex Rodak
09-12-2015 09:39 AM
