Score another for the Raptor
Why two cams? Direct valve acutation - in other words, no rocker arms. Less mass to control at higher RPMs.
Who's the *&#@ing retard who decided that 2 over head cam shafts was better than 1?
I guess they decided to go with 2 cams for the same reasons the *&#@ing retard who designed the YZ426F engine did.
The raptor has 2 carbs???
Well, with 3 intake valves it would definitely make the A/F mixture intake charge more consistent.
How? One carb feeds one valve, the other feeds two - nothing consistant about that - very questionable design.
CC for CC, stock for stock the Z400 develops more power than the Raptor. They must have done something right.
Two carbs are used in order to keep the intake charge at a higher velocity during low RPM operation than would be possible with one large carb. High velocity airflow through the intake runners helps with throttle response and low-end torque, while still delivering enough airflow volume for top end. Actually a pretty good design. The same idea behind dual intake runners on some Hi-performance cars.
Alex Rodak
09-12-2015 09:39 AM
