tires for vinson 5 spd
i have a 2003 vinson 5 spd and want to get aftermarket tires. I am either going to get 27" mud bug's with ITP delta rims or i can spend an extra $200 cdn and get 27" mudlites with ITP C-series aluminum rims. I was wondering what the best choice would be.Thanx
27's will not work on C-Series wheels unless you have a lift and I'm still not sure if they will clear then?You can run 27's on the stock wheels with no lift though.I encountered this problem whenever I put tires on my 5 speed Vinson.If you had a Auto Vinson you could run 28's with no problem at all,but the floorboard brace on the 5 speeds limit's your option's!
I have not got anything yet but I think I might go for 26" mudlites with itp C series rims, I think they should fit without rubbing on the floor board supports. You should have no problem with your tires rubbing since yours is an auto
Sep 30, 2015 01:37 AM
