Z250 Exhaust Question
you can take a 2000 yz 125 silencer by straighten the end of the pipe even with the bottom of the muffler the inlet will slide right into your stock header pipe. The bracket for the silencer goes between the rear grab bar bolt and the stock location upper mount of the pipe. The biggest key is not to jet your carb, problems will occur even if you go to a 135 jet (stock 125) jet is the perfect size already:she will scream for ya!!!! hang on!!!
if your looking for accessories for the z250 check out rockymountainatv.com from that catalog you can select the suzuki (make) z250 (model) and (go) it will give you the bumpers, nerf bars, swing arm skid plate, and the full chassis and a-arm protectors. best prices around actually. good luck!
Yoshi Full & Slip Exhaust, stainless & stainless + carbon fiber.....
http://www.moto-race.com/catalogo/pr...d=44&Prdid=444
