Suzuki LT230S racing mods
Old Jun 3, 2003 | 07:39 PM
230Srider's Avatar
Default Suzuki LT230S racing mods
Hey everyone, whats up? I have a 1985 LT230S and i was wondering what i can do to set it up for XC racing.
Old Aug 17, 2004 | 12:42 PM
HondaCrazy85's Avatar
give powroll a call, they have a 270 big bore for the 230. do you mean mx(motocross) or xc(cross country)? cause if you want a woods bike, call ebc while your at it and order a dirt runner clutch, wich will also work for mx, but it works really well for xc. i would also invest in a better carb, like a keihin/dg carb for a honda 250x. then get some beadlock rims, holeshot tires(hd's are the best, longest lasting), and a dg xcellerator pipe, rejet the carb and a dd a k&n filter with a pre wrap and remove the airbox lid. hope this helps.
Old Aug 18, 2004 | 01:49 PM
tjmax's Avatar
sell the 230 and invest in a bike that is atlest 1990s
Old Aug 18, 2004 | 02:53 PM
yagerzzz's Avatar
Unfortunately, powroll no longer carries their big bore kits for the 230 sport. However, my brother found out about a year ago that they will still sell you the kit but you have to order at least 4 at a time. I just called them 2 days ago to see if they'd still sell it and they said no. Then I mentioned the 4 at a time idea and they sounded interested. I gave them my phone # and they're supposed to call me to tell me if they'll sell it to me that way. I'm still waiting. If they do, I'll probably keep 2 of the kits and sell 2. If I remember correctly, they had a 273 cc kit and you could get up to 12.5 to 1 compression depending on which piston you ordered. They also had cams available. Hopefully they'll still sell the stuff. I'll post a new thread if I hear from them and can get the kits because I'll be looking to sell 2 of them.
Old May 3, 2006 | 11:17 PM
TAG781's Avatar
Hi. How's it going. I just joined the forum and was doing some research and found a post where you stated that a company was selling a big bore kit for the lt230s. I was wondering if they ended up selling them to you? I think my engine is seized and would like to rebuild it with some better performace pieces. Thanks.
Old May 3, 2006 | 11:18 PM
TAG781's Avatar
Did you ever get any of these? I just joined the forum and came across this thread in a search. Thanks!
Old May 4, 2006 | 12:04 AM
BigDimo2624's Avatar
if i were you i would have the piston, and rings checked out and have them replaced if necessary. If all that is fine, clean out carb thoroughly and check the jets. change/ clean the airfilter. put good oil in it. just fix it up so it will run good, and for a long time. sell it and get what you can for it. take that money and save up for a newer bike. not brand spanking new, but newer. THEN start adding goodies. in my opinion it would not be worth spending too much money becasue its so old. i have an '86 LT230 and the only things i spend money on is the things that it absolutely needs.
Old May 4, 2006 | 02:46 AM
loudchevy421's Avatar
if yer lookin for a bigger bore find the number for mad man engineering and give them a clal. they still make a 260 sleeve kit for the 230. its a good little kit ive got er installed on my 86. makess pretty decent power
Old May 4, 2006 | 03:39 AM
yagerzzz's Avatar
Wow. This is a really old thread that got dug up. I haven't been on this board for awhile. Was surprised to see one of my responses on the first thread I read.
Anyway, I never did follow through with the deal. Not enough interest at the time. If I were going to build my 230 tomorrow, I would probably consider other engine builders as well (someone like FTZ perhaps).
There is currently a brand new 260 big bore kit (LA Sleeve) on eBay. Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
It doesn't tell you what the comp ratio is for the piston. I'd be curious. I've heard good things about LA Sleeve though.
Good luck
Old May 4, 2006 | 03:39 PM
TAG781's Avatar
What is required to put in one of those big bore sleeves? Does the head have to be machined? Would the cluctch have to be replaced also? TIA
