z400 sprockets
Old Jun 11, 2003 | 01:35 PM
jt's Avatar
jt
Default z400 sprockets
ok heres the situation...against my brothers trx250r...i pull him out of the hole all the way up to the top of third and bottom of fourth...but after that he starts pullin hard on me...what sprocket setup gets a better top end? tires are stock
Old Jun 11, 2003 | 01:56 PM
LTZ's Avatar
LTZ
That's a tough one!! Usually you will have to sacrafice one for the other, low end for top end. Not sure what the solution is but I think Alba recommends 13/41 as the best combo. Hopefully someone can help ya.
Old Jun 11, 2003 | 02:15 PM
bulldogz400's Avatar
13/41 would be a much lower end power combo. If I were you and wanted more topend- go with a 15 tooth front sprocket. Try it and see how that goes.
Old Jun 11, 2003 | 03:12 PM
FsT4WrD's Avatar
" pipe and jet " if you get or have a pipe for top end gear low and vice versa
Old Jun 11, 2003 | 03:13 PM
Toyguy's Avatar
I'm running a 13/38, I have much better low end, also got good top end.
Old Jun 11, 2003 | 05:05 PM
JeffP's Avatar
Here's a handy chart to come up with different final gear ratios.
http://www.coolskunk.com/ratio_chart.htm
I would also recommend the 13/40 or 41 combo over the stock 14/41. The stock Z doesn't have enough power to pull to redline in 5th gear anyway. In those taller gears it just doesn't have enough useable power to make them useful for accelerating. Dropping to the 13/40 will allow the quad to pull a little easier through those gears because the torque multiplication has been increased at the rear wheels. However you will take about a 2-3mph topend speed hit due to the new gearing. With this gear setup you should be able to reach the rev. limiter in 5th at about 68-70mph. You probably can't do any better then that speed right now with your stock gearing and power level.
Old Jun 11, 2003 | 05:58 PM
FsT4WrD's Avatar
Originally posted by: JeffP
Here's a handy chart to come up with different final gear ratios.http://www.coolskunk.com/ratio_chart.htmI would also recommend the 13/40 or 41 combo over the stock 14/41. The stock Z doesn't have enough power to pull to redline in 5th gear anyway. In those taller gears it just doesn't have enough useable power to make them useful for accelerating. Dropping to the 13/40 will allow the quad to pull a little easier through those gears because the torque multiplication has been increased at the rear wheels. However you will take about a 2-3mph topend speed hit due to the new gearing. With this gear setup you should be able to reach the rev. limiter in 5th at about 68-70mph. You probably can't do any better then that speed right now with your stock gearing and power level.
Explanations don't get any better then that [img]i/expressions/face-icon-small-smile.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
merryman
Sep 19, 2015 03:15 AM
1ArmBandit
Sep 8, 2015 08:59 PM
