ozark wheelie
isnt the ozark 4x4. if it is it is to heavy unless you are a 300lb. man if u are sit on the very back( this is very unconfortable ) flur it from first to second gear and yank up .just make shur that u dont fall of. if it is muddy at your house than it will be nearly impossable. good luck[img]i/expressions/face-icon-small-happy.gif[/img]
01 recon
03 z400 with few mods
01 crappy scrambler 90
02 honda pilot
00 lexus
01 recon
02 honda pilot
00 lexus
Try starting from a stopped position. Just give it some gas while pulling up on the handle bars. If your moving down the trail you could try bumping it up with a ramp shaped rock or something. Just to get used to pulling the front end up.
Put in in 2nd gear, put one foot on the rear rack, and then hit the gas as your pulling up on the bars. That works on my Z250, TOO GOOD. My uncle flipped it over backwords yesterday trying that. But the Ozark is a little bit heavier so you shouldnt have that problem...I hope.[img]i/expressions/face-icon-small-confused.gif[/img]
it is possible to to do a wheelie on an ozark, i usually just put it in 1st or 2nd gear and gun it. sometimes it works and sometimes it doesnt. it all depends on the terrain.
boy are you guys working to hard to wheelie lol the ozark wheelies so f*%#ing easy. pull the shifter up hold it like your about to put it into fist and the rev it up and then drop it into gear and there you go. It works done it alot and its easy well give it a try ut dont go over backwards.
