Motor Time!
Old Jun 17, 2003 | 01:06 PM
nauvooguy's Avatar
Default Motor Time!
O.K., so i have got evrything for the body that i want on my KFX, and I think its time for the motor[img]i/expressions/face-icon-small-smile.gif[/img] So I have new tires, and rims, nerf bars, bumper, pipe and filter with jet kit, and will be getting handlebars shortly. Now I want somthing to run with the big boys. i mostly do short STEEP hill climbs, and tight woods, with some road riding to get there, so I still want to be able to outrun a piped raptor. so what should I do for about $250? A high compression piston, and cam? I have also heard of putting the head gasket off of the DRZ onto the Z, and raising the compression to 12.5? would that be just as good as a piston? Any ideas guys?
Old Jun 17, 2003 | 09:34 PM
nauvooguy's Avatar
Default Motor Time!
No one has any ideas?
Old Jun 17, 2003 | 09:40 PM
Crashman44b's Avatar
Default Motor Time!
I would go with the piston next
Old Jun 17, 2003 | 11:44 PM
nauvooguy's Avatar
Default Motor Time!
O.K. would just a stock bore high compression piston do well, or should i go 440? If 440 what is the cheapest kit out there for the Z? also how much am I looking at for someone to do the machine work? Also what bore would .40 be? What about .60, and .80?
Old Jun 18, 2003 | 03:49 AM
Default Motor Time!
Personally, I would go with the stock bore. I think big bores effect reliablity. SOME, not alot. I would also throw a set of Hot Cams in while I had it apart. Heck, just as well have the head ported to. I'm pretty sure that combo would make most Raptors look silly. Thats what I plan on doing to mine this winter.
If you have a big bore kit put in, I would go with Sparks Racing. I heard his motors FLY. Curry Brothers here in Nebraska do good work on Z's to. Their Z won the 400cc drags at Genoa. The guy winning all the MX races here also said his motor was built by Curry Brothers.
Old Jun 18, 2003 | 12:00 PM
JeffP's Avatar
Default Motor Time!
I just did the DRZE gasket, head porting, and the exhaust cam (already had the intake). It really woke the quad up on the bottom end and mid-range. The topend doesn't feel right yet but I think I have some jetting issues to sort out still. I've only taken one short ride on it since I put it back together.
I'm not really sure which of the peices had the biggest impact but as a set they are working amazingly well. I did the port work myself so it was just a parts cost. Gasket was $20 something, exhaust cam was $125, DRZE valve springs $48 for set (just wanted the insurance down the road for dyna), machine work for 5-angle valve job and reassembly $80.
I'm going for the FCR40mm next and a dyna. If it's still not enough I'll look into more compression or a little more displacment. I'm already getting to the point where it's making more power then the suspension can handle (at least and keep me on it).
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
JackOReilly
Dec 7, 1999 09:12 AM
