mikuni to keihin jetting?
Old Jun 17, 2003 | 03:42 PM
Semms40oz's Avatar
Default mikuni to keihin jetting?
Does any one know the conversion for jets sizes when switching from a mikuni carb to a keihin carb and vice versa. for instance if you ran a 220 main in you mikuni what would be comprable in a keihin carb?
Old Mar 19, 2005 | 12:15 PM
2StrokeSmoke's Avatar
I would like to know the same thing. Any help anyone?
Old Mar 19, 2005 | 06:24 PM
hondabuster's Avatar
Im not sure how this will help, because minkuni jets wont go in a keihin carb, and vice versa. Anyway, i found a dynojet to mikuni jet conversion.mikuni/dyno
And the dyno to keihin keihin /dyno
This assumes the dynojets for mikuni are sized the same as the dynojets for keihin.
I tried finding the conversion for mikuni jet size to diameter size, and keihin to diammeter size, but came up short.
Old Mar 20, 2005 | 12:52 PM
sam250's Avatar
Mikuni and Keihin jet sizes can't really be converted from one to the other. One is numbered based on flow rate and the other is based on bore size.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
