Brand New Eiger- Engine Is "Ticking"
Old Jul 4, 2003 | 02:28 PM
SingleTasker's Avatar
Default Brand New Eiger- Engine Is "Ticking"
Hi Guys,
2003 Eiger 4x4 Automatic- 2 weeks old- Love It!!!
The engine "ticks"- sounds like B-Bs dancing on a piece of sheet metal. Don't know much about engines (can ya tell?). What is this?
Thanks,
Bill
Old Jul 4, 2003 | 04:58 PM
Blitzkrieg's Avatar
trying to audiblize that sound....
does it do it constantly, or just when hot or after you shut it off?
Old Jul 4, 2003 | 09:40 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Mine did this - usually at idle or low speed. Turned out that a lock washer on the auto-clutch shaft was installed backwards. The nut on the end of the shaft would loosen and retighten - It could not come off as it would hit the housing first. Dealer set it right and no noise since.
Jaybee
Old Jul 5, 2003 | 12:35 AM
Shortcut's Avatar
check your oil? maybe valves need adjustment.
Old Jul 5, 2003 | 05:09 AM
bulldogz400's Avatar
That would deifinetly be my guess.
Old Jul 5, 2003 | 12:21 PM
Blitzkrieg's Avatar
The only reason I would sway towards something else is the machine is only 2 weeks old. It would seem odd to me that a brand new machine would come with the valves out of adjustment. (This is a new 2003 and not a used one, yes?)
Old Jul 5, 2003 | 04:08 PM
Yup...... Brand New
Old Jul 5, 2003 | 08:24 PM
SpankyLowe's Avatar
My Z does the ticking thing as well but I'm sure that it's just the valves needing adjusted.(mainly when warm)..
My dealer will take care of it when I take it in for it's first service....
Hope it turns out that that's all yours needs........
Old Jul 22, 2003 | 02:06 AM
Coyotechaser's Avatar
Jaybee
Just came across this on a Eiger search. Just in case you haven't seen this recall for the semi-auto.
www.cpsc.gov/CPSCPUB/PREREL/prhtml02/02507.html
It's about a nut coming loose that secures the clutch shoe. I realize this was an older topic but it might be new to someone.
Old Jul 22, 2003 | 09:52 AM
roosthrower's Avatar
my blaster doesn't tick
