230 E questions
Old Jul 15, 2003 | 07:58 PM
trlbss325's Avatar
Default 230 E questions
I just bought a 230 e Quadrunner today for $400 other then needing a choke and a valve job and some cracks in the plastic it seems like a good deal. Kind of a winter project. My question is.... Are there any common problems I should be aware of. I already have a polaris and the reilabilty has been great with the exception of some self induced problems. ya know handle bars bent rims that kinda thing lol thanks in advance for any info you can share
Old Jul 16, 2003 | 09:25 AM
RacerRichie's Avatar
These bikes are known for throwing chains for a few reasons:
bad swingarm bearings that allow play in the rear.....pops chain off.
incorrect chain slack set at adjustment.(should be 1.0-1.5 inches sitting on it after adjustment.)
When the chain pops off it usually puts a hole in the case near the front sprocket.
Other than that isssue they are rock solid. I have owned many Quadsports and they are awsome.$400 is a good deal if it's not too beat.
GOOD LUCK !!
Old Jul 17, 2003 | 07:39 AM
MBrooks420's Avatar
What year is it? You should buy a case saver before you throw the chain and crack your motor case. The only other "defect" they have is a weak point in the frame on the upright between frame rail and spine. If you are going to be doing a lot of jumping I'd have it gusseted before you crack it.
Old Jul 17, 2003 | 09:11 AM
trlbss325's Avatar
What kind of after market parts are out there for more power. Is this an easy machine to find parts for. Looking at putting a pipe on it. Nothing to extreme though since my wife will most likely be the one riding it
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
