dogging out?????
Old Jul 16, 2003 | 01:28 PM
tg413's Avatar
Default ******* out?????
i have a 91 lt 250 that likes to dog out on steep climbs. i just got the quad and it runs great starts first kick every time. it has prolite piston, hot rod crank , fmf pipe and other work into it , but when i take it to the pits it wants to dog out on the steep climbs even if it's revved out.i am pretty sure its a carb problem but dont know to much about jets and that.any help would be appreciated.
Old Jul 16, 2003 | 01:29 PM
Semms40oz's Avatar
does it only do it while climbing hills or does it do it on flat ground when you hit the top end?
Old Jul 16, 2003 | 01:39 PM
tg413's Avatar
usally only on the hills but it has done it on flat ground.
Old Jul 16, 2003 | 02:15 PM
Semms40oz's Avatar
It sounds like a def. carb problem. Two possibilities: You're main jet is wrong or you're floats are not set at the right level. Check you're plug, if its black or dark brown then you need to go with a smaller main jet, if it looks white or partially melted go with a larger main jet. to adjust the level look at mikuni's web site they should have a guide
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
FWhitt
Jun 13, 2015 02:22 PM
SP500inNS
Aug 25, 2000 01:09 AM
SP500inNS
Aug 3, 2000 07:27 AM
