Where to find pistons bigger than .080" over for Quadzilla?
Old Jul 18, 2003 | 09:43 PM
TomM's Avatar
Default Where to find pistons bigger than .080" over for Quadzilla?
I’ve heard of people boring them to .100" to get 530CCs and also heard they can be bored up to .140" but have never seen a piston listed above .080".
Old Jul 18, 2003 | 11:56 PM
donzilla's Avatar
wiesco makes them i had one 180 over before i resleved it .
Old Jul 19, 2003 | 11:56 PM
DASHIT2K3's Avatar
That where i would look.I only have it bored 60 I dont want to go carzy.I want mine to last a little while b4 i resleeve it.
Old Jul 30, 2003 | 12:52 PM
ranout2wice's Avatar
I haven't seen an answer to this question. I am also in need af a piston and rings and will be looking for someplace to buy one. I brought a quadzilla back to life from it's burial in the back of a field.It was in pieces and covered in Bird dung. After many trips to the hardware store for screws,coil,fuel line, paint,excitor coil it lived. After about 6 laps it stalled so I (picked the bugs out of my teeth first ) then I looked at the spark plug to find a gray plug and small aluminum beads. After taking the head off I found a piston and head that looks like someone sand blasted it with huge sand pellets. My next step is to replace the piston and rings and polish the head(maybe machining 10-20 from the head while I am at it. My question is how do I know which way to turn the stator plate?I think my timing is advanced causing me to burn the piston.(this was one of the original probs. I replaced the excitor coil and put the staor plate back in to the lines)Do I turn clockwise or counter clock wise to decrease the advanced timing?
Other questions: With .80 over what plug should I be using and what is the recomended fuel oil mix.
Awesome machine : The only thing that saved my life were the bald tires.Of course once I get it running right a new set of hoops will be added.
ranout2wice
Old Jul 30, 2003 | 10:11 PM
donzilla's Avatar
on the zilla , clockwise is advance . the stator plate has a mark on it and so does the case half . they should line up for top dead center . im at 60 over and run the ngk br8eg or egv plug .
Old Jul 31, 2003 | 10:57 AM
Thanks for the info. I would have guessed that clockwise would be the opposite.Unfortunatly I took off the jug last night and found a smoked piston and rings. The piston looks real bad like it was sand blasted with BB's. Pretty deep at some points I guess aprox .40" deep. I plan to buy a piston,rings gasket,bushing,etc...I will polish the head out but the sleeve is real smooth.
Not knowing the oil gas mix I used my sons (LEM 50) gas at 32.1
Is this to lean?
I did have the lines lined up on the stator does it sound like I was running advanced?
How much play should my connecting rod have?Mines about 1/8 from side to side?
panicmanic
Dec 15, 2015 01:58 AM
Ashley S
Aug 6, 2015 12:56 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
southbayman
Jul 24, 2015 09:30 AM
