adjusting the power valve
Old Aug 18, 2003 | 11:53 PM
badass500r's Avatar
Default adjusting the power valve
i was wonderng how go you adjust the power valve on the 500
Old Aug 19, 2003 | 12:31 AM
2StrOkeFReaK's Avatar
I dont remember exactly off hand, but I did see how to do it a few months back on an old thread. I know if the actuator rod is not moving and is down and the tension is too tight, type zilla in the search and you will find it.
Old Aug 25, 2003 | 02:24 PM
Duneaddict's Avatar
Okay, starting with no tension on the spring (Take the cap off, and make sure)
the cap/**** should be rotated 180 degrees counterclockwise and locked down... easy as that..
You can tinker with it to have the valve actuate at different RPM if you desire..
Per the manual... 180 degrees CCW is the factory setting.
Cole Hadden
Jun 15, 2025 09:05 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Unzzy66
Jul 11, 2015 10:01 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
