LT250r Specs
Old Aug 23, 2003 | 02:13 AM
gw2k101's Avatar
Default LT250r Specs
Can anyone tell me the specs on a LT250r? Or a website that has the specs?
Thanks
Old Aug 23, 2003 | 04:19 PM
LT250Kid's Avatar
Carburetor: Mikuni TM34SS, flat slide
Lubrication: Oil premix
Ignition: Suzuki PEI (CDI-type)
Starter: Primary kick
Transmission: 6-speed, manual clutch, no reverse
Final Drive: #520 chain, O-ring sealed
Overall Length: 1,830mm (72.0")
Overall Width: 1,135mm (44.7")
Overall Height: 1,125mm (44.3")
Seat Height: 780mm (30.7")
Wheelbase: 1,280mm (50.4")
Ground Clearance: 125mm (4.9"), at rear axle
Dry Weight: 147kg (324 lbs)
Fuel Tank Capacity: 11.5 liter (3.0 gal) including reserve
Front Wheels: AT21x7-10 fully corded tires on aluminum rims, using 4 on 166mm bolt pattern
Rear Wheels: AT21x10-10 fully corded tires on aluminum rims, using 5 on 130mm bolt pattern
Brakes: triple hydraulic disk, single piston caliper designs
Front Suspension Travel: 8.7", double A-arm with adjustable preload and 4-way rebound damping
Rear Suspension Travel: 8.7", "Full Floater" linkage with fully adjustable preload
Old Aug 23, 2003 | 05:02 PM
TomM's Avatar
Specs for the 85-86 models were a little different. They had different wheels and the 85s had a 32mm carb.
Levi Enstad
Sep 26, 2015 08:00 AM
raman8tor
Sep 20, 2015 07:35 AM
Halffast17
Sep 11, 2015 02:30 PM
