loose axle on ozark
Old Aug 23, 2003 | 06:57 PM
SuzukiOzark's Avatar
Default loose axle on ozark
i have some up to down play on my rear axle, side to side it is fine though. is this a huge problem, or can it get one more ride on it? also is it fixable without taking to a shop? thanks
Old Aug 23, 2003 | 07:19 PM
someone must know... hopefully
Old Aug 23, 2003 | 10:17 PM
Shortcut's Avatar
Sounds like a problem that you want to fix before you ride again.are you sure it's the axle and not the rear shock mount?
Old Aug 23, 2003 | 10:35 PM
yeah its the axle, i just need to know how to tighten it. the race quads have the 2 nuts that you tighten but i think these are inside the casing and i dont know how to get that bushing off or get to the nut. i would like to fix it myself because i was planning on going on a trip next week and the shops around by us would never get to it in that amount of time. so i guess if i cant get it fixed im still riding it-if anyone knows anything about the ozark axle please help me out, thanks
Old Aug 24, 2003 | 11:55 AM
MBrooks420's Avatar
Where is the play? If its not side to side, it can't be tightend because its a bearing. The 2 bolts you are thinking of hold the carrier tight inside the swingarm. The carrier turns to adjust the chain. I wouldn't ride it if there is considerable play.
Old Aug 24, 2003 | 07:13 PM
does anyone know how i can fix it myself?
Old Aug 24, 2003 | 07:20 PM
MBrooks420's Avatar
Replacing the carrier bearings is the only way.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
clscott84
Sep 21, 2015 10:16 AM
1000gade
Sep 9, 2015 04:41 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
that1redhead
Sep 8, 2015 11:47 AM
