boreing over
Old Aug 24, 2003 | 12:19 AM
Rider1169's Avatar
Default boreing over
if i get a z400 and then put the yoshi 440 kit in it, your boreing that over right, 40 over? is that ok to do with a new but droken in engine, boring over and will it decrease the life of the engine?
Old Aug 24, 2003 | 03:13 AM
wildchild660R's Avatar
Yes that would be boreing your engine. I dont see any problem about the motor if its already broke in and everything. And any time you mod your quad it can effect its reliabilty then again it may not really. You never know
Old Aug 24, 2003 | 03:17 AM
scrambler123's Avatar
you are boring it 40cc's over not the common term of .040 over.
Old Aug 24, 2003 | 11:52 AM
MBrooks420's Avatar
Generally boring a motor will decrease its realiability. I don't know why everyone is so hung up on big bore kits. They aren't that great. When weighing out the options like cost vs power gained vs reliability concerns usually they are way better mods. I'd do the big bore last. I'd get a pipe, carb, dual cams, heavy duty valve and a slighly high compression ratio piston(On the Z I believe you can simply use the drz base gasket for a small bump.)
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
