1985 LT230 Quadrunner Ignition Switch Help
Old Aug 29, 2003 | 08:15 PM
Cas's Avatar
Cas
Default 1985 LT230 Quadrunner Ignition Switch Help
Helping a friend replace his ignition switch in a 1985 LT230 Quadrunner. Does anyone have a wiring diagram to tell me what wires are what? I believe the red is battery, for the "ON" position what wires are common to the red wire? There is a red, organe, gray, black/white and black/yellow wires that go to the switch. What are the functions for each of these wires? Any helpl is appreciated.
Old Aug 30, 2003 | 10:50 AM
MBrooks420's Avatar
I'd call a salvage yard about getting a used key switch. Wiring it up with a toggle switch is a bad idea. All someone has to do is flip a switch, and you bike is gone.
Old Aug 30, 2003 | 10:50 PM
biggin's Avatar
Red goes to the + battery terminal, via 15 amp fuse.
Orange is connected to the neutral relay ,neutral indicator light, and the engine kill switch
Gray goes to the headlight dimmer switch,dash iilumination bulb, and the taillight.
Yellow/black is connected to the engine kill switch and CDI
Blk/white is connected engine kill switch,headlight,starter soleniod.
What wires make what happen when wires have closed contact via ignition switch:
1) Red and white make the zooter ready to run, just hit the start button ( key in middle position)
2) Red and white and gray, same as above except the headlamp is on ( key in farthest clockwise position)
3)yellow/blk and blk/whit, kills the engine and electrical sysytem ( key in farthest counter clockwise position)
Old Aug 31, 2003 | 11:40 AM
Cas's Avatar
Cas
I thought about that too, so I thought I'd hide the switch somewhere not very obvisious.
Thanks
Old Aug 31, 2003 | 11:42 AM
Cas's Avatar
Cas
Perfect!
Just what I needed. I'll have him back in the woods in no time.
Thanks
skinnyr6
Aug 25, 2023 02:18 AM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
WILLLANE8302
Aug 7, 2015 08:24 AM
