700 Twin Peaks Pics....
Old Sep 13, 2003 | 05:41 PM
kevin00's Avatar
Default 700 Twin Peaks Pics....
Yellow and blue.
Link
Looks nice with Yellow.
Old Sep 22, 2003 | 10:41 PM
BlueOne's Avatar
how does your 02 vin have full reverse override, or did you add it?
Old Sep 24, 2003 | 06:05 PM
kevin00's Avatar
I just did it myself. I've posted this before but here's how if you want to know.
Actually it's very easy. All of the wiring involved is over the left rear wheel, on your CDI module which is mounted directly behind your rear dry storage box.
Cut the blue/red wire to the CDI module. Tape the end to the CDI module. Connect the other blue/red end to the striped end of a diode. Connect the non-striped end of the diode to the white/red wire. be sure of the striped end of the diode or else it wont work.
Any of these diodes will work, you can pick one up at radio shack.
276-1101 1N4001 $0.59 US
276-1102 1N4003 $0.69 US
276-1103 1N4004 $0.79 US
276-1104 1N4005 $0.89 US
Good luck, its very simple and very cheap. This will completly disable the limiter for good so be sure you want to do this before you dive in. your display will work like it did before.
I have done this personally and it works great!! And best of all it only took about a half hour.
If you have any other questions just ask!!
Old Sep 24, 2003 | 11:56 PM
BlueOne's Avatar
Thank you,will try it when I get a chance
Sw00p
Sep 24, 2015 02:50 PM
greg74
Sep 10, 2015 07:58 AM
Jul 7, 2015 11:00 PM
Madshad
ATC 3-Wheelers
Jun 28, 2015 02:43 PM
