Which plow should I purchase?
I'm needing some help. I'm stuck between purchasing a CC, Moose, or Warn plow blade with a manual lift? Any suggestions on which blade to buy? I was thinking about a 48 inch blade. Is that large enough? I have a 2003 Vinson. Thanks
Ihave a moose county plow,60" and a winch to lift it,very smooth and neat.takes 2min,to take off and easy tto put on.No trouble pushing with the vinson,plenty of power to push with,go online to mooseutilities.com and check it out. hopes this helps
take out the 4 stock bolts,replace with longer ones,make sure they go in straight,about a inch,maybe a bit more, the bracket go down, no problem with clearance,I take mine off for summer riding
kampswas
Sep 23, 2015 05:05 AM
