Best quadracer airfilter
Old Sep 21, 2003 | 05:12 PM
bigugly's Avatar
Default Best quadracer airfilter
I am currently running a K&N filter in the stock box with the lid off. I would like to remove the airbox and clamp on a filter with outerwear. I saw that Uni makes some generic ones and I think K&N makes them also. What type do you use and what is the best? Include prices if you can please.
Old Sep 21, 2003 | 05:43 PM
sparkzillA's Avatar
I think the uni is better because it stops more stuff from entering the engine. But the k&n lets morre air through and also smaller peices of dirt.
Old Sep 21, 2003 | 09:11 PM
capecodder's Avatar
i like the uni filter or the moose filter
Old Sep 22, 2003 | 12:14 AM
bigugly's Avatar
Are the filters you bought specific to your quad, or did you measure the diameter of your carb opening and buy a generic filter in the brand of your choice?
How often do you clean them?
Old Sep 22, 2003 | 12:34 AM
chuck1221's Avatar
Get a Uni unless you ride on pavement. Uni filters flow air. not dirt like K&N. I don't know much about any other filters.
chuck
Old Sep 23, 2003 | 02:46 PM
LTSRFASTER's Avatar
I would stick with the K&N with the outer filter, just measure the carb where it will be clamped on. they will usally strech or shrink with the clamp a little measure the length that will fit, they also make them with slight angles to get around the shock . Chaparall out of cali has a good selection at good prices and will help match the pre filter also. I have this set up on my zilla for sand and i only have to clean the filter every couple of rides and its usaully just a pre filter wash. Just make sure you rejet....
03hp300
88 lt500r
92 lt250r
Old Oct 11, 2003 | 12:53 AM
bigugly's Avatar
I finally took the stock airbox off today. Was tougher than I thought it would be. I almost had to take the rear shock off to get it out, what a pain.
Old Oct 13, 2003 | 10:15 AM
Duneaddict's Avatar
Stick with K&N... And use an Outerwear also, keep it clean and you'll have no problems with dirt.
There is NO alternative if you run sand... the foam filters don't stop sand intrusion.
Foam filters are better at filtering in fine powdery dirt.
I'd say it's application specific.
Just my $.02
Old Oct 17, 2003 | 12:10 AM
Snyd250r's Avatar
get and aluminum airbox made for your LT, i just made one for myself and it came up so nice and convert it over so you can run a trx 250r k&n on it. Its the best wasy to go
Old Oct 17, 2003 | 01:25 AM
bigugly's Avatar
I just got he K&N clamp on filter with outerwear today.[img]i/expressions/face-icon-small-happy.gif[/img] Just ordered it 2 days ago from Rocky Mountain ATV.[img]i/expressions/face-icon-small-happy.gif[/img] I have had good luck with them. [img]i/expressions/face-icon-small-happy.gif[/img]
I have been thinking about making a deflector shield to keep water and mud from splashing the filter but havent done it yet. Still in the thinking stages.
