Z400 chain adjustment help!
Old Sep 26, 2003 | 07:19 PM
gduck's Avatar
Default Z400 chain adjustment help!
My adjustments are uneven and after an hour of playing with the bolts, they are only slightly better. anyone know how to get them back in line?
Old Sep 26, 2003 | 07:21 PM
KGB's Avatar
KGB
You have loosened all the pinch bolts? If I remember right there is 4 big ones and a smaller one. If you hav ethe bolts loose, count threads and you should be ok.
There is no disputing that its a crappy system. I am saving up for a new swinger w/ a round carrier.
Old Sep 26, 2003 | 07:41 PM
FsT4WrD's Avatar
It takes alot curse words and tool throwing to get them to line up perfectly , it takes me about 5 ***** fakers and one socket toss to get it right.
Old Sep 26, 2003 | 08:33 PM
SuperSuzuki3's Avatar
DiD YOU TAKE OFF THE REAR CALIPER? EVEN WITH EVERYTHING LOOSE ITS STILL A PAIN. I HAD TO KICK THE SH-- OUT OF THE TIRES ON EACH SIDE TO GET IT TO MOVE.
Old Sep 26, 2003 | 09:42 PM
TahoeRider's Avatar
Make sure the back adjustment bolts are fairly even in turns then pull back on the axle. It should settle back against the adjusters. Then fine tune it slowly until you have correct tension.
This worked well for me.
Firefighter400
Oct 8, 2022 06:38 PM
fordfaithful21
Dec 7, 2015 05:52 PM
goosemasterkl
Aug 23, 2015 11:36 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Jul 15, 2015 02:07 AM
