Quad frame welding prep
Old Sep 30, 2003 | 11:53 AM
stockyM's Avatar
Default Quad frame welding prep
I need to weld my frame but am not sure what precautions to take electronicly. I know to remove the CDI box and am going to remove the resister. But do i need to worry about the stator. Should i remove the engine. I called the local shops and they dont have a clue not that im surprized.
Matt
Old Sep 30, 2003 | 01:36 PM
evhwg's Avatar
what part are you trying to weld with the bike together?
i tore mine down and welded it up and put gussets around
Old Sep 30, 2003 | 08:23 PM
SuzukiZ250Kid's Avatar
I don't think you have to worry about messing up any of the electronics unless the electrical current will travel right through them. As far as I know, unless the engine is running, the current won't draw itself to any other electronic componants. The electric current takes the shortest path possible between the two electrods, so unless the electronic equipment is in this direct path they won't be affected.
Old Sep 30, 2003 | 08:36 PM
stockyM's Avatar
I need to weld the tab on that you bolt the expantion pipe to. It is located directly behind the steering column and just below the CDI box
Old Sep 30, 2003 | 09:53 PM
Dangerous's Avatar
Stocky
Clean paint, dirt, grease, etc. from a spot on the frame reasonably close to the spot you'll be welding. Use this spot to firmly attach your ground clamp. Cover anything spatter or sparks will damage such as wires, plastic, etc. with a fire blanket, wet rags or whatever you have and weld away. The key to not hurting the electronics is to get a good ground and keep it close to where you're welding. If you keep a good ground you will never have a problem.
Frisky2050
Apr 9, 2020 11:19 AM
musselmark
Jul 17, 2015 02:40 PM
toonces
Jul 11, 2015 12:01 PM
RedRancher
Jul 10, 2015 06:36 PM
bikedad3
Jul 2, 2015 02:15 AM
