Eiger Question???????
Old Sep 30, 2003 | 02:21 PM
Eiger376's Avatar
Default Eiger Question???????
I havent tried this yet, can you be moving maybe like 10-15mph and switch the lever to 4WD?
Old Sep 30, 2003 | 06:52 PM
Dewbaby's Avatar
DON'T do it. You can damage the machine if you change to 4wheel drive without stopping.
Old Sep 30, 2003 | 11:21 PM
Eiger376's Avatar
Oh really, but I really dont see how it would hurt anything?
Old Sep 30, 2003 | 11:26 PM
Dewbaby's Avatar
Just letting you know what the manual says. Go ahead and try it at 15 mph and let us know what happens.
W
Old Oct 1, 2003 | 12:26 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Been doing the 2wd/ 4wd switch for years with 'zuki's - first with a KQ and then with an Eiger. As long as you're not under load and pulling hard it will shift in and out easily. Basically just back off the throttle for a second as you shift into 4wd. I know, I know, the manual says not to do it but a few thousand miles and no problems tells me different.
Now, shifting from Hi to Lo is a different story - you must be at a complete stop for that one.
Jaybee
Old Oct 1, 2003 | 02:10 AM
Eiger376's Avatar
hah yea. I think I need to adjust my 4WD lever. It makes a buzzing noise while in 4WD and everyonce in a while I hear a pop noise like metal slamming together or something. When I first got it I could switch the lever from 4wd to 2wd and it would come out right then, but now I have to ride a while before it comes completely out. 4WD works fine but something aint quite right I dont think.
Old Oct 25, 2003 | 12:15 PM
MuddyEiger's Avatar
You can switch from 2 to 4 and back, as long as the tires are not spinning. I do it everytime I ride. Ride in 2 until I get to a mud hole, slow down, flip it into 4 and slam through the hole!
Old Oct 25, 2003 | 01:06 PM
Harw's Avatar
Your front diff is around $1200.00. Your little fingers that lock into four wheel drive will start to round off. Then you will here a poping noise. Then the side of your diff will blow off. Then you spend alot of money. That is why Suzuki tells you not to shift on the fly. The Hondas, Yamaha and Polaris you can shift on the fly.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
