Suzuki 230 information
Old Oct 11, 2003 | 09:49 PM
SuzukiRider99's Avatar
Default Suzuki 230 information
i was wonderin what are the best performance upgrades for a 87 suzuki 230 quad sport. also does a k&n air filter make a diffrence in horse power,and i bought nerf bars about 3 days ago and i was puttin them on and on the directions it says to remove stock foot pegs which i dont understand beacuse if i do then where is my shifter going to sit beacuse its part of the foot peg.
Old Oct 11, 2003 | 10:07 PM
vexing2's Avatar
I put a K&N, drilled some holes in my air box, and a Dg rcm pipe and muffler... sure runs alot better than before.... I am 250 lbs. plus so, on a 230 ..I can notice differences...LOL !! I am waiting on a set of front shocks off a 300ex.. They a about an inch longer but, I hope they help the front suspension..I also upgraded the rear shock to a later model with res...made a world of difference !!
Old Oct 12, 2003 | 01:50 AM
MBrooks420's Avatar
A k&n will help especially with a pipe and jets. The next thing to do to a 230 is cam and valves. Then you can gear it a little taller. Don't the pegs go back on after you install the nerfs? If not a PW50 or pw80 shifter is a shorty shifter that willl bolt right up to the shaft and get rid of the whole linkage assembly.
Old Oct 12, 2003 | 04:06 PM
MalHombre's Avatar
hey Mbrooks, i was wondering what type of shifter i could bolt on. i,m leaving my pegs stock, no nerfs, but i want to get rid of the sloppy shift linkage.
Old Oct 12, 2003 | 09:44 PM
MBrooks420's Avatar
It would be the same. A shifter from a suzuki PW50 or PW80 dirt bike is the most common shifter swap for the 230's I believe. Measure the distance from the shifter shaft to where a shifter would be comfortable and then go to the dealer and have them match up a smaller bikes shifter. Most suzuki's use the same number of splines, and the same shaft size.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
VABrute
Jan 6, 2016 07:39 PM
Sassinm1
Sep 30, 2015 04:23 AM
merryman
Sep 19, 2015 03:15 AM
Sep 1, 2015 11:59 PM
