top end rebuild lt250r
Old Oct 20, 2003 | 12:45 PM
glamisnor's Avatar
Default top end rebuild lt250r
I was wondering if anyone knew of a good site that shows the steps for a top end repuild for a 1989 LT250R? I have only done this rebuild once on this bike and at that time there was a good website that showd the steps to take. I have rebuilt an 86 many times, but this motor is a little different.
Thanks
Old Oct 20, 2003 | 09:53 PM
YFZ450R's Avatar
i've been reading my old blaster clymer manual on how to do a top-end rebuild im shure they are practiculy the same steps seens how they are both 2 strokes and single cylinder,i could walk you through. but your probb going i dont want advice from a 15yr old,he might blow up my engine again.
Old Oct 21, 2003 | 01:24 AM
Slacker1bob's Avatar
Rebuilding one 2 stroke is pretty much the same as rebuilding another. If you can do an 86, you can do an 89. I havnt don a rebuild on a power valve motor, but I cant imagine that it is that different.
Old Oct 26, 2003 | 11:53 PM
LT250R87's Avatar
It's no different except that you have to take off the power valve window and disconect the power valve actuator. You just unsnap the little clip and then disconect the little metal rod.
Old Nov 1, 2003 | 06:41 PM
gt250r's Avatar
im in the same boat as you glamisnor...ive rebuilt a lot of 2 stroke top ends but never a water cooled 1, like my lt250r.. maybe we can both do ours at the same time and compare notes lololol........... im just afraid mine may need a little more ...motor sounds kinda rattley..... im pretty sure top end needs to be redone compression is defenatly down when cold ........would appreciate any input from memebers
Old Nov 1, 2003 | 11:10 PM
MOJAVE02's Avatar
start the rebuild and any problems you arrive at let me know i will walk you through them. i have a lot of experience with these engines and also any other engine you might have questions about. good luck
mark
Old Nov 2, 2003 | 12:09 PM
gt250r's Avatar
thanks mark for your offer of help.........i would like to continue to ride til the weather gets too cold before the rebuild ........so i have justa question for now ............ when engine gets hot and i come to a stop idle revs high..do you think this could be a air leak??? engine does not respond to idle adjustments by way of idle set screw.. but if i adjust the cable at the throttle idle will go down...but still hangs up high when coming to a stop?????? installing a new cable today before i go riding ill see what happens .....what do you think???? thanks Gary
Old Nov 2, 2003 | 08:06 PM
MOJAVE02's Avatar
let me know if the new cable helped or not. if not then it could be an air leak, that is what it sounds like.
Old Nov 2, 2003 | 08:16 PM
gt250r's Avatar
replaced the throttle cable today.......still does the same thing .......im thinking that maybe there is a idle jet problem.....because when i installed the cable with proper amount of free play motor woulnt even start..but if i adjusted the cable tighter it would start but same old problem of reving when hot .. not to mention a fouled plug cut my riding day short .........any suggestions thanks again gary
Old Nov 2, 2003 | 09:02 PM
MOJAVE02's Avatar
pilot air jets, pilot jets, if not those than more than likely an air leak. try richening the PAJ's.
