top end rebuild lt250r
Old Nov 2, 2003 | 11:18 PM
gt250r's Avatar
Default top end rebuild lt250r
ok mark will try that .......but if it is a air leak where would the most likely place for these motors to suck air when hot ????
Old Nov 2, 2003 | 11:25 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
I will be watching this thread.
I have a practically virgin lt250r motor that needs to be built and put back in its frame.
the swingarm and motor are the only things holding me back now
does anyone know a good LT motorbuilder????
Old Nov 4, 2003 | 09:12 AM
MOJAVE02's Avatar
i would say for an air leak check where the head pipe mounts to the engine(exhaust leaks will burn down an engine quickly if not fixed), check all the components of the powervalve system(many people would disagree with me but these things can malfunction and cause an air leak, and lean that engine right out). that is all i can really think of right now, those are the basics to check. and Bing to answer your question i like CT for the 250's. they have some real nice packages. you also might look into trinity they have a good amount of kits for these bikes. remember these bikes respond very well to porting. so if you are looking to just do a mild build up i would change to a high compression head, 38 or 39mm carb, port, aftermarket piston and rings, and a very good exhaust system and that bike will rip.
Old Nov 4, 2003 | 01:29 PM
gt250r's Avatar
ok mark will check those things ........CT??? do they have a web site
Old Nov 4, 2003 | 02:17 PM
  #15
MOJAVE02's Avatar
www.ctracing.com they have a kit for $450 where the port the cylinder, mill deck and rechamber the head, new gaskets, and a little bit more work as well. there are alot of companies just do a search online.
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Halffast17
Sep 11, 2015 02:30 PM
