LT 250R Questoin
Old Oct 25, 2003 | 02:31 AM
manual's Avatar
Default LT 250R Questoin
Well there is a 87 LT-F250R for 2800.00 obo im wondering if this is a good deal, its in good conditon, fenders seat and all looks great
prtd, plshd, lazor lights, cscde seat cvr & light cvrs, Nerf bars, FMF pipe/slencer, cool head, 18cc domes all for 2800.00 OBO is this a good deal or not? Looks in great condition, or would i be smarer to spend a extra 400-500 on a 86 trx250R that is piped?
debatting between a few bikes right now
Old Oct 25, 2003 | 11:23 AM
manual's Avatar
any advice?
Old Oct 25, 2003 | 02:15 PM
swampdonkeykiller's Avatar
$2500.00 tops
Old Oct 26, 2003 | 01:53 AM
kruzoffman's Avatar
dud thats a prettey good deal i love the lt's nice bikes i wounld go for it.
Old Oct 26, 2003 | 04:47 PM
manual's Avatar
question: on this LT250R, does this compare anywhere with a stock banshee in a drag? is the LT250R a good trail bike, or is it mainly just for MX?
Old Oct 26, 2003 | 10:02 PM
LT250R87's Avatar
the LT250R is a great all around quad. It has good all around power. The suspension isn't as plush as others, but the faster you go the better it gets. Do not go above $2500 for one though. With the new Z400's and YFZ450's you should not even have to pay that much. Absolutely do not buy it without looking it over thoroughly though. With a machine that old, there is a lot of chance for wear. Check all of the bushings and bearings. Get the wheels up in the air and shake them really good to check the wheel bearings. Shake the axle really hard to check the axle bearings. Definitely check the swingarm pivot bushings for play because those things are a pain in the butt to replace. one very important thing is to check the frame for cracks. The LT250R frame is prone to cracking on the bottom frame rails towards the back tires and around the swingarm pivot. Stand the quad up on end. If it has a skid plate, remove it and check the bottom frame rails for cracks. Also check around the swingarm pivots. If this is all good, go for it. For every set of bushings or bearings that is loose, subtract $100 from the price because this is what it will cost you in parts and time to replace. Absolutely do not buy a quad with a cracked frame, because even if you weld it, it will never be the same.
Old Oct 27, 2003 | 04:26 PM
Icehouse's Avatar
Compared to the price of new quads these days that is definately a reasonable price but remember that it is also a 13 year old machine and may require maintenance maybe alot of it if it was neglected. I got mine for 1800 but spent 2000 to get it where i wanted it . You can go two ways, either buy one and upgrade it yourself or buy one that already has everything done to it. I would buy the one in the best shape and mostly all stock and upgrade it the way you like .
Old Oct 27, 2003 | 06:51 PM
kruzoffman's Avatar
yea i diffenetly did knot check over my lt before i bought it that good. i mean i checked the swing arm bearing axle bearing stuff there were tight but later on i blew them out. pain in the butt to put theme in and when i went to go put the axle bearing in i found out that the axle carrier had crackes and holes in it so that needed to be replaced well eneyway's yea make shure it is in good shape and test drive it for a while to make shure.
Old Oct 28, 2003 | 06:26 PM
LT250R87's Avatar
I hear ya kruzoffman. I bought my LT about 5 years ago and have since sold it, but it took me about 3 years to replace everything that was worn out on that thing. I doubt any of the previous owners had ever greased or replaced anything. I could probably tell you the size and torque specs on just about every bolt on that machine from tearing everything down to replace bearings, bushings, pistons, etc... I'm not saying don't buy something that needs a little work, but know what you're buying. I sure didn't know what I was getting when I bought mine. I learned my lesson with that quadracer and now I baby my new Z400 to make it easier on myself later.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
