quadracer weight
Old Oct 25, 2003 | 05:21 PM
1991lt250r's Avatar
Default quadracer weight
suzuki says dry weight for the lt250r 87-92 is 324 not true. I work at a company that sells landscape products and used the scale to way my quad (91lt250r) it say 371 but i put on fmf pipe and silencer much lighter than stock how can that be? I do however have bandits on front and sherdders on rear and i added dg nerf bars but took off those heavy steel heel guards. That 371 was with half tank of fuel and full crankcase. what do think?
Old Oct 25, 2003 | 07:28 PM
Slacker1bob's Avatar
That sounds pretty heavy. The 85/86 LT250 has a claimed dry weight of 275
Old Oct 26, 2003 | 02:37 AM
1991lt250r's Avatar
come on lets hear what you think. what does your quad weight, not (claimed dry weight ) the real weight. thanks
Old Oct 26, 2003 | 12:34 PM
I know my quad weighs under 300lbs. Roughly around 180lbs.
Old Oct 27, 2003 | 01:24 AM
85lt250r's Avatar
your quad weighs 180 lbs?????????????????????????????????????????
are u sure?????? thats soooo light.
Old Oct 27, 2003 | 02:04 AM
LT250RSuperstar's Avatar
Ok kids my manual for my '86 says mine wieghs 293lbs. dry.....thats without fuel, coolant and gearlube.
later
Superstar
Old Oct 27, 2003 | 07:47 AM
MBrooks420's Avatar
There is no way your atv weights 180 lbs unless you took the torch, and drill press to it. 125cc dirt bikes weigh more.
Old Oct 27, 2003 | 11:47 AM
Sorry, bad typo, 280lbs
Old Oct 27, 2003 | 04:16 PM
Icehouse's Avatar
I weighed my 89 lt250r on a truck scale and it weighed 285 lbs. I have aluminum grab bar, bumper, nerf bars , and handle bars. I have an lrd pipe and silencer which is significantly lighter then stock. I dont have a head light mounted which shaves about 10 lbs already. I also removed the stock air box and run a k&n right off the carb. I hacked off those dumbo ear front fenders and removed the fender mounts ( dont crash or bye bye plastic !!). A truck scale is designed for high weights so it may be innacurate but i think its about right. I had gear oil and a little gas when i weighed it.
Old Oct 27, 2003 | 04:18 PM
Icehouse's Avatar
I think you mean 180 kilos not pounds dummy!
