aftermarket cv joints of 03 eiger
Old Oct 25, 2003 | 03:17 PM
dakotajerry's Avatar
Default aftermarket cv joints of 03 eiger
Dose anyone know where to find aftermarket cv joinst for an 03 eiger
Old Apr 11, 2004 | 05:06 PM
joshpascoe's Avatar
Hey
what's the reason that you are looking for aftermarket cv joints? Did you break yours, that happened to me. w/b if you ever found any. Also, I have a question about CV joints if you know. Inside the wheel where the outer CV joints is located there is a bearing that goes around the joint. Do you know if I can just replace the bearing rather than spending $300 on the entire part? Thanks a lot!
Josh
Old Apr 11, 2004 | 10:14 PM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
I bought heavy duty CV's for my Vinson from Rockford Constant Veloscity. You could try them at 1-800-728-7237. Sean is the guy that dose ATV's his extention is 307. The heavy duty one are a lot bigger that stock ones.
The part # for the Vinson is D2015/182RT might be the same for the Eiger.
You can look at a microfise for that bearing at www.ronnies.com.
fd24
Jan 16, 2019 08:59 AM
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
89Lt250r
Sep 7, 2015 07:53 PM
