Z400 JETTING
Old Oct 27, 2003 | 03:44 PM
btbell's Avatar
Default Z400 JETTING
I JUST PUT A FULL YOSHI EXHAUST SYSTEM ON MY Z400. WHAT JETTING SHOULD I RUN FOR THE SAND DUNES AT GLAMIS? WHAT IS THE BEST WAY TO GET THE 4 SCREWS OFF THE BOTTOM OF THE CARB BOWL TO CHANGE THE JET?
THANKS
BTBELL
Old Oct 27, 2003 | 07:10 PM
raptor03's Avatar
looking for the same info!!!
Old Oct 27, 2003 | 08:08 PM
LTZ's Avatar
LTZ
I've got just a MBRP slip-on, lid off, snorkel removed, Uni filter w/Outerware and I run a 160 main, about 2 1/2 turns out on mixture screw, and stock pilot at Dumont and the desert and it runs great. I would think it would be the same for Glamis but haven't been there yet. Hope this helps.........
<edit> The screws can be a b%&$h!! I was able to get mine out no problem, but if you strip 'em try slotting 'em with a Dremel and use a flat head screwdriver or something similar. Replace them with Allen heads, much easier......
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
