250 suzuki wheel lock up
Old Oct 31, 2003 | 09:11 PM
imasuckyrider's Avatar
Default 250 suzuki wheel lock up
I have a 01 suzuki 250 my front left wheel had locked up. There is no apparent reason and can not find why it happened. Any suggestions? Also does anyone's quad overheats and is hard to start after a long ride?
Thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 31, 2003 | 10:31 PM
RaptorOwner's Avatar
Sounds to me you got water in your bearings and it rusted up pretty good.
Old Nov 1, 2003 | 02:24 AM
MBrooks420's Avatar
Well the first thing to do is start pulling things off. If you pull the wheel you will have a better look at the brakes, which could be at fault. Your bearings may have siezed, which also may cause a overheating problem. I'd get the wheel moving, and then I'd solve the overheating before it ruins the motor.
Old Nov 5, 2003 | 08:30 PM
Thanks am going to try to start digging around this weekend, good first hint as to where to look
Old Nov 5, 2003 | 08:35 PM
Funny you should mention brakes were having problems with them a month or so ago and had to tighten, I wonder if I over tightened. Any thoughts on if, pulling a 600 Grizzly about 2 miles out of the woods (up and down) might have affected it?? I brought it to a shop (with the Grizzly) they said mine was fine and fixed the swing arm on the Grizzly, but am still a little skeptical that it may have done something to my quad.
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
merryman
Jan 19, 2016 04:29 AM
Nekolai1
Aug 25, 2015 10:04 PM
Findlay Tulloch
Aug 25, 2015 05:00 PM
