do i need a valve adjustment?
Old Nov 13, 2003 | 12:16 AM
jt's Avatar
jt
Default do i need a valve adjustment?
on a z400, what are the symptoms that it needs the valves adjusted??? does it do anything in particular?
Old Nov 13, 2003 | 02:09 PM
rockrider's Avatar
You are supposed to check/adjust them at 10hrs.
Old Nov 13, 2003 | 02:12 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
It will tick,,,,and loose performance.
It is always a good idea to keep your valves in check.
Old Nov 13, 2003 | 05:28 PM
BUDXXX's Avatar
Yeah, check em. If they are loose they might tick, but if they are tight, you may not hear anything. After the new engine runs for a while (break in period) valves will generally become tighter....because the valves pound on the valve seats, guides,..typically causing them to seat deeper (closer to the tappet)....narrowing the gap between valve and tappet.....
If your valves become tight enough you could experience loss of compression, backfiring, the carbs could pop off the intake boots...or worse.
Buy the manual, get the tools, maintain your ride. Have fun.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
