230 smokes
Old Nov 15, 2003 | 04:12 PM
Vinson581's Avatar
Default 230 smokes
does it need rings and a new piston
Old Nov 15, 2003 | 07:59 PM
Vinson581's Avatar
Default 230 smokes
has any one done a rebuil and how hard
mbrooks?
Old Nov 16, 2003 | 12:30 AM
Polaris500HO4x4's Avatar
Default 230 smokes
its your piston rings letting oil through there worn out. i have never rebuilt a quad but i guess u need to know what your doing.
Old Nov 16, 2003 | 05:12 AM
MBrooks420's Avatar
Default 230 smokes
If it still runs good I'd disagree with the rings being solely to blame. Is it hard to start? Doing a top end on a 230 is cake. The hardest part is pulling the motor. On it's out its simple. I'd pull the head and take it to the shop and see what they think about the valve components. Don't you have 2 motors? You could swap heads to see what happens. If it turn out to be valves a shop will swap them out for fairly cheap. If you are going to replace them I'd get upgraded ones with stifffer springs.
Old Nov 16, 2003 | 11:38 AM
Vinson581's Avatar
Default 230 smokes
it runs poor and is hard to start, because of oil in cyclinder. and on plug. i do have 2 motors, but the cyclinder in the other one is scratched.
Old Nov 16, 2003 | 08:57 PM
MOJAVE02's Avatar
Default 230 smokes
do a leakdown and compression test. if they are both good there is no reason to rebuild just a waste of time and money. could be oil seals or valve seats a little soft. top end rebuild is simple. if you are willing to pull it down i will answer and help you with any questions you might need or problems you might face.
Old Nov 16, 2003 | 08:58 PM
Vinson581's Avatar
Default 230 smokes
k great
Old Nov 19, 2003 | 02:52 PM
Specialyst's Avatar
Default 230 smokes
i got some 230e parts for sale or trade if you have some 230 parts have pics include
pipe
plastics
headlight
front fender brace
carb
cylinder(cracked)
airbox
Old Nov 19, 2003 | 03:38 PM
Vinson581's Avatar
Default 230 smokes
plastic? $?
Old Nov 19, 2003 | 03:40 PM
Specialyst's Avatar
Default 230 smokes
whats your email?
