Checking oil in Quadracer
Old Sep 20, 1999 | 07:47 PM
SnowJer's Avatar
Does anyone know how to check the gear oil in a quadracer 250?
Old Sep 20, 1999 | 08:15 PM
chrisjack's Avatar
no, i dont know how to check it, but i do know how to change it, which would be your best bet if you havent done it in a while. ive had mine for 3 months (my quadracer) and ive changed the oil 5 times i think. Theres a bolt on the bottom of you engine (on the underside) i think its a 22mm but im not POSITIVE you just loosen that and take it out and there comes the oil, the on the ride side of the engine on the "jug" there is a cap that is black and you unscrew that and put 900ml in (make sure you put the bottom blot back in dooough) then put the cap on, and wala its good to change that often, i do it every 3 tanks or so of gas i run through it, a bottle of it is only like 4 bucks i think, so its CHEAP preventive matinence.
Hope that helps.
Chris Jack
87 LT250r "BaCk In BlAcK"
Old Sep 21, 1999 | 02:02 PM
qrdude's Avatar
It depends on the year. The 85-86 has a bolt u take out on the side of the case and thats how u check it. On the 87-92 there is no way to check it...just make sure u have the right amount in there
Old Sep 23, 1999 | 12:22 PM
RoostKing's Avatar
I have an 85 Quadracer and I have not seen this "bolt" on either case to check the oil.
ALos, Warm up the quad for about 5 minutes to get the oil warm, it helps drain all of the oil.
RoostKing...
Old Sep 23, 1999 | 01:30 PM
qrdude's Avatar
Its on the right side near the bottom and up near the front of the motor. The Clymer manual shows it.
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
