gas drip
Old Dec 4, 2003 | 01:07 PM
terd's Avatar
Default gas drip
whenever i rock the quad side to side,you can see gas drip out of the carb over flow tube.
when it is still,the drip stops.the gas odor is starting to bother me.it's that strong.
any ideas on how to stop this besides clamping the tube??much thanks
Old Dec 4, 2003 | 09:59 PM
Vinson581's Avatar
Default gas drip
my guess would be at the bottom of the carb there is a screw, and then the line, at the bottow of the float bowl area. make sure it is tight. this should be your problem..
v581
Old Dec 5, 2003 | 02:08 PM
terd's Avatar
Default gas drip
it's tight(the screw)any other ideas?
Old Dec 5, 2003 | 02:26 PM
robnhouston's Avatar
Default gas drip
Your float is set to high. Fuel is filling up the bowl then splashing out. It would also do this when your riding.
To fix you must remove the bowl and bend the float arm. Bend it down so it shut off the fuel sooner.
Old Dec 5, 2003 | 11:59 PM
teoamaru's Avatar
Default gas drip
I agree, its probably your float adjustment. Give it a try.
Old Dec 8, 2003 | 12:35 PM
terd's Avatar
Default gas drip
thats what i think also.i bet it happened when i crashed into my buds parked 400ex.
it probably set it out of adjustment..thanks,i will let you know.
bmxatv10
Oct 14, 2022 06:23 PM
Rainman
Dec 23, 2009 07:50 PM
roscoe69
Dec 15, 2002 07:50 PM
stebob
Jan 7, 2002 11:23 AM
