Suzuki 250 4x4 vs 3004x4 Kingquad
Old Mar 16, 2013 | 10:28 PM
mla2ofus's Avatar
I've gotten pretty attached to my '96 250 4x4 quadrunner. 'Course we're both old so maybe that's why,LOL!! It plows snow well in the winter w/ a 54" blade and the wife and I ride it in the mtns a lot in the summer.
Mike
Old Mar 17, 2013 | 12:24 AM
JustRandy's Avatar
Its about the best quad for getting from A to B
Old Mar 17, 2013 | 07:09 AM
mla2ofus's Avatar
If you're not fussy about being the first to arrive at "B".
Mike
Old Mar 17, 2013 | 10:03 AM
TLC's Avatar
TLC
Originally Posted by TickMagnet
Hey Bill, is there really no difference in power? I bought a '99 KQ this past April. I looked at the 250 first but went ahead and got the King. 10-4 on the tires but they do whaT I ask them to, I just go around the really BAD mud holes. I'll never win any races but I just wanted a quad to slow trail ride, hunt/fish/camp, and work. I'm keeping my eye on the Rubicon as a possible future big bore quad, hope it turns out a good track record, it'll be at least a few years before I buy. I've been having a blast on my King Quad, it does exactly what I wanted it for, not to mention that I can't seem to run the thing out of gas!
have fun!
The KQ would be better in the mud than a Rubicon. The KQ not only has low range it has a ultra Low range when you engage AWD Diff lock.
Honda is the only company that has no diff lock sysytem. They did put it on the side by side Big Red but none of there 3wd ATVs have the option yet.
The only differeance between the 250 Quadrunner and 300 King Quad is the 34cc and the KQ has larger front wheels. http://www.atvreviewnetwork.com/enth...cle1=27&go2=Go
There not big motored ATVs but with the 15 speed tranny they have they do not need to be.
Old Mar 17, 2013 | 12:27 PM
  #15
JustRandy's Avatar
The 300 is 50lbs heavier.
The 250 is a little narrower in the front... The cv joint axles in the front are shorter.
The 250 has stiffer ovate valve springs and a cdi that seems to have more advance and a higher rev limit.
They have slightly different cams
The 300 has a beefer rod which I believe is a bit longer too.
The 300 has an extra clutch disk
The 300 has a super beefy cam chain which I can't imagine would ever fail
There may be some other differences I haven't stumbled on yet.
Maybe the 250 doesn't have an oil cooler? The 300 does.
Power-wise, they're pretty close, but the 300 has much more potential to be built into a beast than the 250.
Using acceleration times over 350ft and F=ma equations, I calculated a 78% increase in power over stock on my 300. It sounds crazy, but that's what the numbers say.
800lbs from zero to 31mph compared to 1000lbs from zero to 37mph, both over 350ft.
Old Mar 17, 2013 | 04:34 PM
  #16
Mattpreat's Avatar
The only differeance between the 250 Quadrunner and 300 King Quad is the 34cc and the KQ has larger front wheels. 1999 Suzuki King Quad ATVs
As far as I know Honda just has a different type of diff lock system on it. I'm still not sure how it works but both from tires will be working as if a diff lock was on when they are spinning. On my 400 kingquad I can spin around in circles in 4wd in the same spot, with a Honda 420 I cant because of the front locking up.
Old Mar 17, 2013 | 04:52 PM
  #17
TLC's Avatar
TLC
I ride with a 500 Foreman and 420 rancher all the time and they always behave like this.
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
