Ozark
Old Dec 18, 2003 | 08:36 PM
Greenhat's Avatar
Default Ozark
I am new to atvs and plan on buying my first one in the spring. I would like to hear from Ozark users. Tell me the pro and cons of your machines.
Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 18, 2003 | 08:39 PM
zrider182's Avatar
Default Ozark
do u want a utility atv or a sport?
Old Dec 18, 2003 | 08:44 PM
Greenhat's Avatar
Default Ozark
I am mostly interested in an utility atv. Right now I'm thinking the Ozark 250. I want someting for yard and forest work but also be able to play on trails. The Ozark is within my price range.
Old Dec 18, 2003 | 10:19 PM
Dawg93's Avatar
Default Ozark
From what I see, Ozark looks like a good buy. I really like the full floorboards. Nice to have these when going through mud, puddles, and water.....keeps the feet dry.
Old Dec 18, 2003 | 10:29 PM
zrider182's Avatar
Default Ozark
yea then go with the ozark, unless u find something else that you like.
Old Dec 19, 2003 | 01:31 AM
atvguy217's Avatar
Default Ozark
go with the ozark its the best quad in its class unless you want something less sporty and can haul more then get the arcticcat 250.
Old Dec 19, 2003 | 01:43 AM
RedGoblin's Avatar
Default Ozark
I'm probably going to get chewed out for this since we're in a Suzuki forum, but I would suggest the Honda Recon. Personal preference just because I've never ridden an Ozark and I'm sure they're just as good, but I can vouch for the Recon. It's actually got quite a peppy little engine for a 250. Plus, you can get the ES version, which has a handlebar-mounted shifter instead of foot, which is really smooth and you can shift if your high-centered in mud or rocks. With a standard foot shifter, there may not be room underneath the shifter to down-shift and give you better torque if your in the situation above. Plus, you've got that Honda reliability that I never seem to shut up about. Just a thought you yellow fans! Don't tear me up too bad!
Old Dec 19, 2003 | 09:20 AM
Elbongo's Avatar
Default Ozark
You made a good point RedGoblin.The recon is a good choice also.The recon isn't as fast as the Ozark but it has stronger bottom-end power. Both are good atvs, just pick what you prefer. I would try and see if you can test both of these four-wheelers and see which one you like better. good luck in making your decision[img]i/expressions/face-icon-small-smile.gif[/img]
clscott84
Sep 21, 2015 10:16 AM
that1redhead
Sep 8, 2015 11:47 AM
traumajunkie
Jul 5, 2015 03:03 PM
ragewraps
May 27, 2015 08:07 AM
