Ltf500f backfires
Old Oct 31, 1999 | 02:39 PM
rburns's Avatar
I just got a new LTf500f. Almost every time I shut it down, I get a backfire out of the tail pipe. Is this normal?
Russ Burns
Old Oct 31, 1999 | 07:23 PM
Bill.Ciliberti's Avatar
Absolutly not normal.Your more than likly dealing with too lean a carb mixture.Dont run it to long like that either.Get it back into the dealership and have that problem looked at.----BILL
Old Nov 24, 1999 | 08:06 PM
quad500's Avatar
MINE HAS BEEN BACKFIRING FOR 1.5 YEARS....IT IS NOT LEAN...IT IS JUST LOADING UP WHEN U SHUT IT OFF AND THAT IS WHAT IS CAUSING THE BACKFIRE...IT JUST KEEPS THE CARBON CLEANED OUT HAHAHA
Old Nov 24, 1999 | 09:29 PM
r34's Avatar
r34
I just bought the 2000 issue, and when I test drove the unit, it backfired when I turned it off as well. I took it back to the shop and asked about it before I bought it. Whatever they did, fixed it, and it has never happened since. I will ask them what they did and get back to you.
Old Nov 29, 1999 | 09:09 PM
r34's Avatar
r34
I asked the service manager what he did to stop my LT F500 from back firing, and he said that he fattened it up a bit to run a little richer, and it has'nt done it since. I'm interested to know what color your plug is when you take it out ??
Old Dec 1, 1999 | 07:30 AM
boomer's Avatar
If its backfiring when you shut down or when you are decelerating down a hill in a lower gear with no throttle, try turning the idle mixture screw out in half tourn increments to richen the mixture a little.
Boomer '99 Wolverine
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
