gas guzzlin Z?
Old Dec 28, 2003 | 12:41 PM
zbutcher400's Avatar
Default gas guzzlin Z?
my z goes through gas like no other, i know i have a smaller gas tank compared to my old polaris, but my freinds cannondale doesnt do this and it has the same size tank! i ride for 4 hours and my i will need fuel, is there somethin wrong somewere? any of you guys had this problem? evry time i want to go riding i need to get gas, its like the hummer if all quads, it get like 3 miles to the gallon..lol. thanks for your help!
2003 z400-renthal barsm dg nerfs
Old Dec 28, 2003 | 01:59 PM
WISTECH's Avatar
The z has a much smaller tank than a cannon .Have you done an actual mileage check?
Old Dec 28, 2003 | 02:58 PM
i thought the dale had the same size tank, 2.5 gallons? but its not htat old, only 2 months. no i havent done the mileage check yet.
2003 z400-renthal bars, dg nerfs
Old Dec 28, 2003 | 03:16 PM
hondabuster's Avatar
Probably isnt that bad...figure it this way, its about 4 bucks to fill the tank, and thats only a buck an hour to ride. I know when im 4x4 in snow, my foreman is around 10 mpg, between the cold weather, slippery conditions, added resistance of 4x4, and goosing the thumb, the thing really eats the gas.
Seeing how you have 2x4, chain drive, and 200 lbs lighter, i doubt its less than 10mpg.
Old Dec 28, 2003 | 03:22 PM
WISTECH's Avatar
You should be able to get around 50 to 60 miles per tank. I have been getting about 65 to 80 miles on a tank depending on conditions.
Old Dec 28, 2003 | 11:01 PM
SukiZ400rdr's Avatar
Went on a 50 mile ride during break in with my Z, and I got about 38 mpg, the best in the crowd!! I
was riding with 4wd ATV's with CVT's, so this makes sense. They are running higher rpm's constantly,
while with the Z you are shifting. I couldnt have been happier. It is probably getting better now that
it is broke in, havent checked...
Anyways, I guess if it seems like it is eating fuel more than it should, have it checked out.
Old Dec 29, 2003 | 05:54 AM
rockrider's Avatar
Funny that you have the same quads I do. Last fall I went on an epic adventure ride with my brother and let him ride my Mojave. Predictably the Mojave went on reserve first while my KXF never hit reserve but was pretty empty when we got back. I've noticed that my KXF uses more fuel than I'm used to, but that's coming off a 250. I think it does okay for a 400.
Old Dec 29, 2003 | 11:46 AM
CHEWBACCA's Avatar
i think its a 2.8 gallon tank, same as my Z250, but yeah i think theres something wrong if ur only gettin 4 hours
Old Jan 2, 2004 | 12:16 PM
Zhvonte's Avatar
The most I ever gotton out of a 4 gallon desert tank is 62 miles and that's was taking it easy.....
Old Jan 2, 2004 | 06:02 PM
KFX400man's Avatar
I've got 2 '04 KFX400s and I've checked the mileage twice on them and each time I was getting around 20mpg, all I ride is trails.
They are both stock. I can go around 50 miles on a tank if I let it go real low. Any mods to yours to make it use more fuel?
